Date/Time: Wed, 05 Feb 2025 19:57:32 +0000
Data feed fees
View Count: 799
[2020-03-29 18:37:39] |
User161549 - Posts: 81 |
I am aware of the new CME data fees being increased just not exactly sure how much it different it will be relevant to what i currently pay now I use the CME with Market Depth for nonprofessional Trading accounts Would you be able to give me a layout of what i am currently paying versus what the updated cost will look like so i can adjust funds appropriately. Thank you |
[2020-03-29 18:55:22] |
SC Support - Posts: 1927 |
Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) The CME Market Depth Bundle (CBOT, CME, COMEX, and NYMEX) goes from $15.75 to $32 for Non-Professionals The CME "Top Of Book" Bundle (CBOT, CME, COMEX, and NYMEX) remains at $3.25 for Non-Professionals Date Time Of Last Edit: 2020-03-29 18:56:32
[2020-03-29 21:27:56] |
So just to be clear i have the CME market depth bundle ? And my cost will be the $15.75 to $32 ? |
[2020-03-29 21:36:00] |
I pay 36 monthly for advanced features and then i pay i believe 30.50 a month for the Denali exchange data feed
[2020-03-29 23:36:10] |
Hi User161549, Service Package 5 is $36 (or as low as $25 if you pay for 12 months): Description of Service Packages and Pricing: Multiple Month Purchase Discount Since you are on TTFIX Order Routing, Denali is $20 then the CME Exchange (only) with Market Depth is $10.50 As you write correctly above, the most you would be paying is $66.50 |
[2020-03-30 02:30:52] |
Okay thank you for the breakdown so i guess it turns out i will not be affected by the change in fees because this is the same amount i am paying already ?
[2020-03-30 05:31:16] |
We will be adjusting the cost of the CME fees for the Denali feed. They should only be marked up 3-4% which covers card processing costs.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-30 05:31:31
[2020-03-30 13:08:45] |
Okay i will take a look once the update goes through and see how much the change is. Also noticed on the forum it spoke about only being able to use one PC for sierra is this correct ? I currently use two different PC's with sierra downloaded on both and the both run at the same time Will this no longer be available ? If so is there anything i can do to fix this issue Thanks in advance |
[2020-03-30 13:14:30] |
From this Notice here, see post #3 Notice: CME Fees Price Increase / Denali Exchange Data Feed Connection Management Denali Exchange Data Feed clients will now be allowed up to 3 connections on the same system but there is a limit to the number of simultaneous systems for the Denali Exchange Data Feed of 1. Later we expect it to be possible to access this data feed on two different computer systems at the same time, up to 2 simultaneous connections, paying 2 separate Exchange Fees. |
[2020-03-30 13:53:09] |
Thats ridiculous, so your saying i will no longer be able to use two different PC's simultaneously and the only option will be whenever you guys make it possible to access this data feed on two different computers i will have to pay 2 seperate exchange fees ? Thats just ridiculous What will the seperate exchange fees look like will it be a duplicate of the data feed itself or will it be the $3.25 additional fee or in my case i believe mine is $10.50 |
[2020-03-30 14:59:18] |
The 2nd Exchange Fee will be based on the type of Data you are using, for example the CME Market Depth Bundle is $30, the 2nd Data Feed would also a $30 Exchange Fee as well, if you were requesting the same data. Also if you just needed Real-time Top Of Book Data on your second system, the Exchange Feed would be $3.25 for the bundle. Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) |
[2020-03-30 15:21:09] |
Are you able to have 2 separate data feeds to achieve this purpose ? I dont believe i need the market depth for the second system i need it on my main system to watch the footprint and orderflow charts on my second system i just monitor the TPO and volume profile charts so not sure if that requires market depth or not but it would need to be a live data feed to track and watch the E-mini /ES contract on those type of charts so if there is an different additional data package i can purchase to achieve that and also at a much lower rate than that seems like my only option |
[2020-03-30 15:25:44] |
Sorry just to be clear i am aware that most if not all data packages will be able to access footprint/orderflow charts, i mean more in regards to the speed and reliability of the connection of the data feed is something im more after i dont need a data package that has the potential to lag or anything like that. So if one of these other less expensive packages has that potential to perform significantly different from the one i have now then it wouldnt be something i am interested in |
