Date/Time: Wed, 05 Feb 2025 19:06:42 +0000
bid volume per bar
View Count: 643
[2020-03-29 08:15:41] |
User719206 - Posts: 93 |
Hello, I would like to use a BID volume per bar and ASK volume per bar as type periode bar , is there a way to do that ? Thanks
[2020-03-29 09:23:55] |
We do not understand this.
[2020-03-29 16:03:10] |
ochocinco - Posts: 29 |
If you are asking for a custom bar period type which starts a new bar when either "bid or ask volume of the current bar reaches X" then you would need to look at ACSIL Custom Chart Bars. ACSIL Interface - Custom Chart Bars There is a working example of total volume per bar which could be modified for total bid or total ask volume per bar. |
