Date/Time: Sat, 18 May 2024 06:22:24 +0000
Lines between chart books same symbol not copying
View Count: 504
[2020-03-28 22:39:54] |
owendonk - Posts: 53 |
Horizontal lines aren’t copying between chart books for me. All charts are SPY. I tried the instructions listed here: Copying Chart Drawings from Other Charts Automatically Chartbook1:1,Chartbook2:1 format not working. |
[2020-04-10 09:13:32] |
We really have to get these two Chartbook to be able to test this. The format you are using does look correct. So we are not sure what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
