Date/Time: Thu, 17 Sep 2026 20:15:18 +0000
Keyboard Shortcut: Move to Break Even
View Count: 1471
[2020-03-28 13:42:01]
User94606 - Posts: 327
Is there a way to customize the keyboard shortcut "Move to Break Even" to "Move to Break Even + 1 Tick" for long position and "Move to Break Even - 1 Tick" for a short position?
imageKeyboard Shortcut.PNG / V - Attached On 2020-03-28 13:41:52 UTC - Size: 26.34 KB - 413 views
[2020-03-31 04:57:33]
Any updates?
[2020-03-31 08:25:50]
User907968 - Posts: 883
Assuming you mean to lock in 1 tick profit in each situation (and not 1 tick less than B/E for short).
You can set the B/E offset in the trade window - Basic Trading and the Trade Window: Set >> Move to BE Offset
[2020-03-31 11:43:09]
That is correct, I want to lock in 1 tick profit for either B/E long and short. For a B/E long position, would this be +1 and for B/E short position, would this be -1? How do I setup these 2 entries?
Also, would this setup work when using the keyboard shortcuts (move to break even key)?
Date Time Of Last Edit: 2020-03-31 11:45:42
[2020-03-31 12:13:08]
Just set the desired B/E offset amount, no need to set separate values for long or short.
Re keyboard shortcut, yes, just make sure to configure the BE offset in any relevant trade windows.
