Date/Time: Mon, 25 Nov 2024 04:30:27 +0000
Tick bar charting issues
View Count: 1165
[2014-01-11 12:22:30]
calitrader - Posts: 28
http://www.sierrachart.com/image.php?l=1389442624705.png
Hi
I am having trouble with higher time frame tick charts. The 500 tick chart I am using displays and draws properly but the 4000 and 10000 tick charts are all printing as exactly 1 hour. Is there a setting I need to change? Thank you.
Chris
[2014-01-11 20:37:43]
This is a symptom of the fact that the chart data consists of 1 minute data.
Refer to:
https://www.sierrachart.com/index.php?l=doc/DTNIQFeed.html
http://www.sierrachart.com/index.php?l=doc/helpdetails47.html#NumberofTradesorVolumeData
If you require only futures data, our recommendation is to use the Sierra Chart Real-time and Historical Futures data feed:
http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php
