Date/Time: Tue, 04 Nov 2025 18:18:18 +0000
Plot Overnight session High Low on RTH session using Price Over
View Count: 6491
[2013-04-15 03:18:11]
SherKhan - Posts: 19
I have regular trading hours (PST) chart with Daily OHLC study. However, I want to display a line on this chart from session start to session end, marking the overnight High and Low. I tried with Study Price Overlay but I can see only a small dash being displayed on the chart. I want to show a line till the end of the session.
How can I achieve this ?
imagePrice Overlay Issue.png / V - Attached On 2013-04-15 03:18:03 UTC - Size: 36.87 KB - 1599 views
[2013-04-15 04:35:41]
Have a look at the High/Low For Time Period studies:
http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s313
You will need to use this on a chart that has the the overnight session and overlay it on your regular session chart.
Also check the inputs for the Study/Price Overlay study. You probably will want to use Fill Blanks with Last Value.
Date Time Of Last Edit: 2013-04-15 04:36:01
[2013-04-15 07:06:39]
I had setup exactly suggested by the help artical. You can verify in the attached chart image in my previous post. It is not working. Please help
[2013-04-15 07:21:27]
Worked. Thanks
