Date/Time: Fri, 07 Feb 2025 20:05:09 +0000
Senkou Span in Spreadsheet
View Count: 597
[2020-03-27 09:09:33] |
User564539 - Posts: 27 |
How can i see the future values in the spreadsheet for the Senkou Span, seems it only ends on the current timeframe.
[2020-06-12 15:23:01] |
No response for 3 months
[2020-06-12 19:04:04] |
This is not supported.
[2020-06-12 19:54:28] |
Ackin - Posts: 1865 |
It's supported - you bypass the shift ...Sierra is a very dynamic software in this The values for the future are only shifted values by 26 bar forward ... Make a duplicate of the study and in the subgraphs tabs in the setting give displacement to the value "0" Then just consider this adjustment in further calculations .... Date Time Of Last Edit: 2020-06-12 19:55:46
