Date/Time: Thu, 06 Feb 2025 02:58:15 +0000
Wickless Candles Erratic Behaviour
View Count: 747
[2020-03-26 18:14:29] |
User803872 - Posts: 14 |
I like to trade without wicks, but often it is so difficult to right click and add an order accurately because the bars jump up and down erratically. When price slows down, the problem goes away. I'm using SC in wine, I don't know if that is an issue. Or a setting in the charts (I have various range settings) v2857M 64 bit (was the same in 32 bit) |
[2020-03-26 21:23:26] |
So we can understand this better: Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-26 22:42:25] |
You won't see it from a screenshot. May I provide a screencast?
[2020-03-27 07:46:37] |
Go ahead and upload a video. But make sure it is attached here. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile And also log into your actual Sierra Chart account in use by selecting Help >> Support Board from within Sierra Chart. Do not use an expired account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-27 12:50:55] |
Hi Start watching after 0.58 and watch the right hand margin (as well as all of the visible bars) jumping as the bars move into new blank territory. I have tried experimenting with different scale ranges, but to no avail. Many thanks |
[2020-04-03 12:02:09] |
Are you guys still looking into this one?
[2020-04-03 12:25:33] |
This is definitely related to your Scale settings. How exactly do you want your chart to behave and we will tell you what Scale Settings to use.
[2020-04-03 17:19:21] |
Very kind of you. I just want wickless candles that are less jumpy. Many thanks |
[2020-04-06 13:48:51] |
John - SC Support - Posts: 37769 |
It is really best if you can tell us how you want your chart to behave and then we can point you to the proper settings for the scale. But, one setup that we think may work best for you is the following: - In the Price Scale right-click with your pointer and select Scale Settings - Select Constant Range - Select Re-Center when the Last Bar Exceeds a Certain Number of Ticks from the Center for the Constant Range Scale Mode - Select OK You may need to adjust your scaling to ensure that your bars are correctly on the screen when you first do this setup. You will find more information on these settings here: Chart Scale and Scale Adjusting: Scale Range (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-13 15:16:41] |
Thanks very much guys that fixed it for me :)
