Date/Time: Fri, 28 Feb 2025 13:37:41 +0000
Market Depth Historical Graph - Scale Cant View Depth Bars or Numbers
View Count: 873
[2020-03-25 15:54:58] |
User896244 - Posts: 1 |
http://www.sierrachart.com/image.php?Image=1585151387474.png I cannot currently view the depth bars or the values for the study on a main graph. The depth bars are so thin that I cannot see or read them. I have reviewed all of the settings, I have changed the settings, and I have read the documentation. The view is similar to Auto Scale the Chart DOM where the numbers are thin and squeezed or where they are overlapping the below animated image, selecting Auto Scale the Chart DOM would clearly fix that problem. I cannot find any similar scale setting for the Market Depth Historical Graph. Stated another way, it seems that the height of the market depth bars is so thin that the bars are barely visible and the numbers in font size 8 are so large that they are not readable because the bars are too thin. |
[2020-03-25 20:25:34] |
The data is at each tick, so it can become necessary to spread out the chart in order to see the values. There is no other option for this at this time. We are also working on combining the data so it can be displayed at larger increments than just the tick size. We hope to have this available in about a month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-20 02:22:05] |
Manerva Funding Financial - Posts: 16 |
Has there been a solution to this specific issue ?
[2021-08-23 13:54:25] |
John - SC Support - Posts: 38259 |
Yes. On the Market Depth Historical Graph there are two options available. Refer to the documentation for the following and the one after it: Market Depth Historical Graph: Combine Increment in Ticks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
