Date/Time: Thu, 06 Feb 2025 14:07:47 +0000
problems with BMF signal
View Count: 547
[2020-03-25 15:54:16] |
User420291 - Posts: 44 |
Good morning, The BMF signal isnt working. I had this issues some time ago, and the support told it was a bar issue. The Market already open, so it was important to sold it as soon as possible. |
[2020-03-25 18:25:19] |
Barchart has resolved this issue earlier but we see that there was still a problem with UMJ20. Barchart has been told about that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-25 18:25:26
[2020-04-30 16:13:19] |
Godd aftermoon. Im getting the same problem with BMF signal today. It started +- 2 hours ago. Thank you. |
[2020-04-30 17:51:22] |
We are checking on this.
[2020-04-30 18:09:42] |
What is the symbol you are having trouble with? We do not see a problem with the BMF data feed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-30 18:09:55
