Date/Time: Wed, 05 Feb 2025 16:46:18 +0000
target/stops nomatch
View Count: 989
[2020-03-25 15:05:41]
User745789 - Posts: 356
I can't find much in the documentation Attached Orders
Is it really the case that Attached Orders have to match quantity?
Can I not have a very co0mmon order set, such as: Stop Loss for all units, Limit Target for some.
[2020-03-25 18:50:48]
It is not required that the Attached Order quantities match, the quantities for each Stop or Target just cannot be greater than the main order quantity. Refer to the information here:
Attached Orders: Order Quantity Matching
[2020-03-26 02:32:10]
I am not able to achieve this.
Main Quantity = 3
Stop All Quantity = 3 [All OCO groups]
Target1 Quantity = 1 [OCO Group 1]
NoMatch displays in red.
I am still able to place an order. If I have execute an order using these settings, filled for 3 units: then the attached working stop loss and target are both working for 2 units.
Date Time Of Last Edit: 2020-03-26 02:32:36
[2020-03-26 03:47:32]
That configuration is not supported. Target quantity must be 3.
[2020-03-26 04:31:14]
Thank you. So the only fudge workaround is to set another target order for the balance of qty many ticks away. A dummy order which is hard to manage because it is likely not even visible on the trade DOM, it is so far away.
Date Time Of Last Edit: 2020-03-26 04:32:42
