Date/Time: Wed, 05 Feb 2025 17:05:21 +0000
bid ask vwap
View Count: 757
[2020-03-25 14:48:51]
User719206 - Posts: 93
hello ,when i use vwap study i can choice volume total bid volume or ask volume , the probleme is all 3 show the same courb , there is no difference . may be i did something wrong, can you help me ?
[2020-03-25 19:14:22]
You also need to set the option for Base on Underlying Data to Yes. Refer to the following:
Volume Weighted Average Price (VWAP) with Standard Deviation Lines
