Date/Time: Mon, 25 Nov 2024 04:51:36 +0000
Net change on quote board not posting
View Count: 1131
[2014-01-10 21:33:42] |
Lawrence B - Posts: 11 |
The net change for the day is posting only selectively on both the chart and the quote board. How do I fix this. I reloaded the software but didn''t help.
[2014-01-10 21:41:38] |
You are using Interactive Brokers. You will need to contact them about it. The data comes from them and if it is not provided you will not get the net change.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-10 21:41:53
