Date/Time: Wed, 09 Sep 2026 21:15:52 +0000
Heatmap
View Count: 10306
| [2020-03-24 13:47:04] |
| User674416 - Posts: 6 |
Hi could someone tell me how i can get the heatmap to my chart were it has numbers in them and different blocks with different bid/ask price. |
| [2020-03-25 08:12:42] |
Refer to the documentation for the Market Depth Historical Graph here: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#Market_Depth_Historical_Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-03-25 17:29:11] |
Hi Could you please have a look at the attached photo i'm trying to get the heatmap on a different window as shown on the attached photo. Could you please tell me how to do it this way. |
| Attachment Deleted. |
| [2020-03-26 14:50:21] |
| John - SC Support - Posts: 47821 |
First, follow the instructions here to get the Market Depth Historical Graph on your chart: Market Depth Historical Graph: Step by Step Instructions Then set the input for Show Quantity Numbers to In Bars. Refer to the information here: Market Depth Historical Graph: Show Quantity Numbers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-03-26 20:21:36] |
HI I have added it on step by step and even changed the study to show quantity in bars. However it is still not being placed in a separate window it attaches it self to the window i have already have open and i can only see it with candles not just the blocks and price moving from block to block. |
| [2020-03-26 20:50:51] |
Yes, that is correct. The study is added to the chart that you are viewing at that time. It does not put it in a separate chart/window. If you do not want the candles to display, then select Chart >> Graph Draw Type >> Blank.
| [2021-07-04 22:37:24] |
| j4ytr4der_ - Posts: 947 |
Was just looking for a heatmap as well and found this thread. Unfortunately it looks like there was a miscommunication on what was being asked for. The "heatmap" that the Market Depth Historical Graph gives, I believe is not what was being asked for and is also not what I'm looking for. I'm looking for what is commonly referred to as a "heatmap" in the tock trading world, specifically something like this: https://vividmaps.com/wp-content/uploads/2020/09/stock-map-1280x720.jpg I'm fairly sure this isn't a feature in SC at this time but if I'm right... is there any chance something like this could be added? And if I'm wrong, how would I go about generating this sort of view of an index? |
| [2021-07-06 14:16:57] |
With respect to post #7: This is not something we have available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
