Date/Time: Wed, 05 Feb 2025 16:58:32 +0000
Eurex no live data
View Count: 524
[2020-03-24 10:04:54] |
User351605 - Posts: 82 |
Hello, I can't receive live data from Eurex exchange if I connect with my SC Data Feed account. The message Log says Logon error received from server: Connection Limit Exceeded. I have two copies of Sierra running, one with my CQG account and one copy with SC Data Feed. Although I can access live CME data ( on SC Data Feed instance ), Eurex doesn't work. Why is that? |
[2020-03-24 20:45:22] |
This means that you have two installations of Sierra Chart using the data feed. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Connections You need to disable Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds on the installation where you do not want the EUREX data, and reconnect to the data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-24 20:46:52
