Date/Time: Wed, 05 Feb 2025 15:52:30 +0000
Unable to Open Chartbook
View Count: 481
[2020-03-24 08:18:23] |
Aidas Kaspar - Posts: 5 |
Hi, Im having trouble opening this chartbook. I have attached a screenshot of the error message and a copy of the chartbook itself. Thanks! |
Error message.JPG / V - Attached On 2020-03-24 08:16:16 UTC - Size: 51.52 KB - 206 views SierraChartReviewTest.cht - Attached On 2020-03-24 08:16:52 UTC - Size: 484.75 KB - 385 views Private File |
[2020-03-24 10:12:08] |
That Chartbook is old and is no longer compatible with newer versions of Sierra Chart.
