Date/Time: Wed, 05 Feb 2025 16:01:07 +0000
Data Missing
View Count: 487
[2020-03-24 03:55:31] |
hatem hosny - Posts: 57 |
Hello, Gbp/Usd, i went back to 1985 historical data(day timeframe),it gives me a chart with many gaps between days with zero volume. Is this data correct?( i can not upload image, there is an error). hatem hosny |
[2020-03-24 10:15:30] |
There may be these issues with data far back in time. We definitely cannot help with this. The only thing we can do is just remove that data altogether. To solve the problem with uploading chart images, update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
