Date/Time: Mon, 25 Nov 2024 04:39:26 +0000
Combining and Splitting volume profiles
View Count: 2185
[2014-01-10 20:34:33] |
Mike_B - Posts: 16 |
Does anyone know if there is a way to merge with previous volume profiles, split them, or merge with next profiles exactly the way you can in TPOs? If someone can point me to the right direction on how to do this, would be appreciated. |
[2014-01-10 21:29:55] |
This is only supported with TPO Profile Charts. It is also possible to add the Volume by Price study to a TPO Profile chart and indirectly support splitting and merging of volume profiles.
[2014-01-10 22:03:07] |
Are there any plans to incorporate this capability in the future? If not, can you please ask for me. Thanks.
