Date/Time: Mon, 25 Nov 2024 03:58:19 +0000
spacing
View Count: 1139
[2014-01-10 19:49:53] |
infpz - Posts: 826 |
any way to reduce how much space is used here (right hand side)?
[2014-01-10 20:01:02] |
It is automatically set. So no it is not possible to reduce it further.
