Date/Time: Wed, 05 Feb 2025 15:49:28 +0000
large volume circle not transparent
View Count: 592
[2020-03-23 04:37:46]
User392279 - Posts: 67
Hi, I find when set draw volume text to yes. Circle turns to solid. I need it in transparent. thanks.
[2020-03-23 05:14:28]
It is not supported to display Text with this study and at the same time have the transparent circles or rectangles. You need to set the Text option to No.
