Date/Time: Mon, 25 Nov 2024 04:36:37 +0000
[User Discussion] - Orders from Command line
View Count: 1169
[2014-01-10 17:20:02] |
fspisem1 - Posts: 12 |
Hello, please, is there any way how to add, manage a Orders via Command line interface or via DLL library? Thank you for answer. |
[2014-01-10 17:39:42] |
Refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_ACSILTrading.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-14 11:24:47] |
Could you ask programmes, if there any way to add Order via external program - running like external source code (VB, C#) (not via internal SierraChart ACSIL) Is is possible to use TAOrderServerAPI.dll or another dll to add Order? Thank you |
