Date/Time: Wed, 05 Feb 2025 14:06:49 +0000
[User Discussion] - Live Chart Trading Order Fills Entry/Exit Connecting Lines
View Count: 879
[2020-03-21 23:07:15] |
User120942 - Posts: 71 |
@Sierra Chart Engineering, Currently the "Chart Trading Order Fills Entry/Exit Connecting Lines Primary/Secondary" only appear on the chart after the trade has closed, connecting the entry and exit fills. Is it be possible to have the lines display during the live trade using the the best bid or ask as a proxy for the exit (depending on if it is a long or short order) until the trade is closed and the true exit is confirmed, instead of only displaying the lines after the trade has closed? Chart Trading and the Chart DOM: Resolving Problem Where Order Fill Entry/Exit Connecting Lines Do Not Display This would be helpful for visualizing scale in, scale out positions. I know this might be a tough lift but wanted to confirm whether or not this is possible. Thank You |
Chart Trading Order Fills Entry Exit Connecting Lines.png / V - Attached On 2020-03-21 22:59:11 UTC - Size: 21.74 KB - 255 views Resolving Problem Where Order Fills Entry Exit Connecting Li.png / V - Attached On 2020-03-21 22:59:17 UTC - Size: 63.89 KB - 277 views |
