Date/Time: Mon, 25 Nov 2024 04:45:46 +0000
SC datafeed missing data for EMD
View Count: 1473
[2014-01-10 14:12:41] |
Peter Power - Posts: 70 |
I was downloading data after yesterday´s interruption for all markets which I am trading currently, using the EDIT->Delete all data and download function. And I successfully downloaded data for all markets except EMD. If I do the same on EMD, I still see the gap from 16:22 until 16:38 GMT. And BTW. I am missing also data for EMD for today from 13:24 until 13:30 GMT. Any toughts? |
[2014-01-10 16:12:46] |
We will patch this over the weekend. I am missing also data for EMD for today from 13:24 until 13:30 GMT. Any toughts? The data should be there. Please perform a download from just before 13:24 by right clicking before the missing data and select Delete Data and Download.Also, when you are missing only some data, please avoid the use of Edit >> Delete All Data and Download. Instead just right-click before the missing data and select Delete Data and Download. It is more efficient and creates less load on the server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-10 16:36:36] |
It is not working. I tried also before yesterday´s interruption and also before today´s gap. Here is the log file Reloading all charts with filename: EMD-201403-GLOBEX.scid | 2014-01-10 16:33:03 HD Request # 18 - Downloading Intraday chart data for EMD-201403-GLOBEX to the file EMD-201403-GLOBEX.scid. Service: cme | 2014-01-10 16:33:04 HD Request # 18 - Download start Date-Time: 2014-01-10 13:21:41.0 | 2014-01-10 16:33:04 HD Request # 18 - Using server: scdf1.sierracharts.com port 10149 | 2014-01-10 16:33:04 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-01-10 16:33:04 HD Request # 18 - Error downloading historical Intraday data for EMD-201403-GLOBEX. The network socket has been closed. Retrying download. | 2014-01-10 16:33:24 HD Request # 18 - Received 0 records and wrote 0 records for EMD-201403-GLOBEX | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.414000, Low = 13.414000, Time Difference = 11392 seconds, Percentage = 32.088000%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.414000, Low = 13.414000, Time Difference = 11392 seconds, Percentage = 32.088000%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11392 seconds, Percentage = 32.088000%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11392 seconds, Percentage = 32.088003%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11392 seconds, Percentage = 32.088006%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11392 seconds, Percentage = 32.088006%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.411999, Low = 13.411999, Time Difference = 11394 seconds, Percentage = 32.090998%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.411999, Low = 13.411999, Time Difference = 11394 seconds, Percentage = 32.090998%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.411999, Low = 13.411999, Time Difference = 11394 seconds, Percentage = 32.091001%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11397 seconds, Percentage = 32.095498%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11397 seconds, Percentage = 32.095498%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.411999, Low = 13.411999, Time Difference = 11400 seconds, Percentage = 32.099998%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.411999, Low = 13.411999, Time Difference = 11419 seconds, Percentage = 32.128498%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.411999, Low = 13.411999, Time Difference = 11419 seconds, Percentage = 32.128501%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.411999, Low = 13.411999, Time Difference = 11419 seconds, Percentage = 32.128501%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.411999, Low = 13.411999, Time Difference = 11419 seconds, Percentage = 32.128501%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.411999, Low = 13.411999, Time Difference = 11419 seconds, Percentage = 32.128504%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11422 seconds, Percentage = 32.132998%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11422 seconds, Percentage = 32.133001%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11422 seconds, Percentage = 32.133001%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11427 seconds, Percentage = 32.140499%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.411999, Low = 13.411999, Time Difference = 11434 seconds, Percentage = 32.150996%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.411999, Low = 13.411999, Time Difference = 11435 seconds, Percentage = 32.152498%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11441 seconds, Percentage = 32.161498%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11444 seconds, Percentage = 32.165998%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11453 seconds, Percentage = 32.179499%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11453 seconds, Percentage = 32.179499%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11453 seconds, Percentage = 32.179499%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.412999, Low = 13.412999, Time Difference = 11453 seconds, Percentage = 32.179502%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.411999, Low = 13.411999, Time Difference = 11453 seconds, Percentage = 32.179505%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.411999, Low = 13.411999, Time Difference = 11453 seconds, Percentage = 32.179505%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.411999, Low = 13.411999, Time Difference = 11453 seconds, Percentage = 32.179505%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.410999, Low = 13.410999, Time Difference = 11453 seconds, Percentage = 32.179508%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.410999, Low = 13.410999, Time Difference = 11453 seconds, Percentage = 32.179511%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.410999, Low = 13.410999, Time Difference = 11461 seconds, Percentage = 32.191497%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.410000, Low = 13.410000, Time Difference = 11462 seconds, Percentage = 32.192999%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.410000, Low = 13.410000, Time Difference = 11464 seconds, Percentage = 32.195997%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.409000, Low = 13.409000, Time Difference = 11475 seconds, Percentage = 32.212496%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.409000, Low = 13.409000, Time Difference = 11475 seconds, Percentage = 32.212499%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.409000, Low = 13.409000, Time Difference = 11475 seconds, Percentage = 32.212502%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.409000, Low = 13.409000, Time Difference = 11475 seconds, Percentage = 32.212502%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.407999, Low = 13.407999, Time Difference = 11476 seconds, Percentage = 32.213998%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.407000, Low = 13.407000, Time Difference = 11476 seconds, Percentage = 32.213998%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.407000, Low = 13.407000, Time Difference = 11476 seconds, Percentage = 32.214001%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.407000, Low = 13.407000, Time Difference = 11476 seconds, Percentage = 32.214004%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.407000, Low = 13.407000, Time Difference = 11476 seconds, Percentage = 32.214004%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.407000, Low = 13.407000, Time Difference = 11476 seconds, Percentage = 32.214004%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.407000, Low = 13.407000, Time Difference = 11476 seconds, Percentage = 32.214007%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.407000, Low = 13.407000, Time Difference = 11476 seconds, Percentage = 32.214010%. | 2014-01-10 16:33:24 HD Request # 18 - Historical error filtered for EMD-201403-GLOBEX, Prior High = 1343.699951, Prior Low = 1343.699951, High = 13.407000, Low = 13.407000, Time Difference = 11476 seconds, Percentage = 32.214010%. | 2014-01-10 16:33:24 Added 78 Time and Sales records to Intraday data file for EMD-201403-GLOBEX after download. | 2014-01-10 16:33:24 HD Request # 19 - Downloading Intraday chart data for EMD-201403-GLOBEX to the file EMD-201403-GLOBEX.scid. Service: cme | 2014-01-10 16:33:24 HD Request # 19 - Download start Date-Time: 2014-01-10 13:21:41.0 | 2014-01-10 16:33:24 HD Request # 19 - Using server: scdf2.sierracharts.com port 10149 | 2014-01-10 16:33:24 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-01-10 16:33:24 The network socket is connected. | 2014-01-10 16:33:24 HD Request # 19 - Sending historical data logon request message. | 2014-01-10 16:33:24 HD Request # 19 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2014-01-10 16:33:24 HD Request # 19 - Decompressing data. | 2014-01-10 16:33:25 HD Request # 19 - Receiving Intraday data for EMD-201403-GLOBEX starting at 2014-01-10 13:21:41 | 2014-01-10 16:33:25 HD Request # 19 - Timestamp of first Intraday data file record written: 2014-01-10 13:22:05 | 2014-01-10 16:33:25 The network socket for historical data has been closed. | 2014-01-10 16:33:25 HD Request # 19 - Received 6198 records from 2014-01-10 13:21:41 to 2014-01-10 16:33:25 (3.2 hours) and wrote 6197 records for EMD-201403-GLOBEX | 2014-01-10 16:33:25 HD Request # 19 - Intraday download COMPLETE for EMD-201403-GLOBEX | 2014-01-10 16:33:25 Real-time Intraday chart data file updates started for EMD-201403-GLOBEX | 2014-01-10 16:33:25 |
[2014-01-10 20:06:51] |
We are going to be testing this.
[2014-01-11 04:03:59] |
All of the settings look correct for Interactive Brokers for EMD. We have also restored the missing data. Go to the chart and select Edit >> Delete All Data and Download. Let us know if all of the data looks good. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-11 04:04:47
[2014-01-11 10:26:33] |
Now I got the missing data from 9th of January but I am still missing approximately 6 minutes from 10th of Jan from 13:24 until 13:30.
[2014-01-11 14:46:51] |
When analyzing the last two days of trading we can see their was/is no trading in EMD from 8:26 to 8:29 New York time . So what you see is normal.
[2014-01-11 16:24:17] |
Wow that really didn´t cross my mind. Thank you and sorry for confusion.
