Date/Time: Wed, 05 Feb 2025 13:57:50 +0000
Extended rectangle
View Count: 984
[2020-03-21 01:29:50] |
User575399 - Posts: 326 |
When I create an extended rectangle I like to modify text to rectangle via right click “Modify text “drop down . Question is, can I make the text color different than the extended rectangle color?
Date Time Of Last Edit: 2020-03-21 02:56:51
[2020-03-21 22:45:09] |
No this is not supported.
[2020-03-21 23:29:31] |
I their a way to left click and move my extended rectangles? I have left click enabled , but I have to right click move drawing as of now .
