Date/Time: Mon, 25 Nov 2024 04:36:02 +0000
TPO or Volume Profile in a custom defined period
View Count: 1736
[2014-01-10 13:29:48]
User70995 - Posts: 3
Is it possible to select specific zone on a custom time frame bar chart and to get TPO and/or Volume Profile of this period there with all levels functionality (POC, VAH, VAL, Extremes...)?
Thank you
Date Time Of Last Edit: 2014-01-10 13:33:57
[2014-01-12 10:14:23]
Yes. Both the Volume by Price and TPO Profile Chart studies have input settings to control the starting Date-Time and the ending Date-Time for the displayed profile. Refer to the documentation for both of these studies for instructions.
Date Time Of Last Edit: 2014-01-12 10:27:00
[2014-01-12 10:26:40]
Documentation links:
http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html
http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html
[2014-01-12 11:05:03]
Am I right that there is no way to select this period by dragging the rectangle or other drawing instruments on a chart manually?
[2014-01-12 11:05:51]
If yes, do you plan to arrange this feature?
[2014-01-15 09:15:41]
In the case of Volume Profiles you can use the Tools >> Draw Volume Profile drawing tool.
Date Time Of Last Edit: 2014-01-15 09:15:54
