Date/Time: Wed, 05 Feb 2025 13:53:43 +0000
Stock quote via Sierra Exchange data feed via Sierra Chart Package 3 through AMPFuture
View Count: 657
[2020-03-19 20:59:20]
User214233 - Posts: 7
Hi, is there a way for me to subscribe to Sierra Exchange data feed if I have Sierra Chart Package 3 through Ampfuture?
[2020-03-20 00:53:54]
Yes, you can use the Sierra Chart Data Feeds with your AMP account. If you just need the CME Group of Exchanges, then you would use the Denali Exchange Data Feed, which you can also have billed through AMP (just ask AMP to get it setup for you).
If you need data for exchanges other than the CME Group, then you would need to use the Sierra Chart Exchange Data Feed and this you would need to pay for directly to us (Sierra Chart). AMP does not have access to turning on/off that feed nor billing for it.
You will find more general information on the data feeds available from Sierra Chart here:
Real-Time Exchange Data Feeds Available From Sierra Chart
[2020-03-20 02:23:36]
I have CME group of exchanges through AMPfuture as well.
In my case all I need is stock data from Sierra Chart. So is it accurate to say that all I need to do is sign up for Sierra Exchange data with Stock data feed? Thanks
[2020-03-20 03:43:21]
Yes that is correct.
