Date/Time: Wed, 05 Feb 2025 14:02:01 +0000
trade simulation mode
View Count: 602
[2020-03-19 20:40:55] |
Ferenc Sand - Posts: 3 |
i can trading live account bec it says it do you want to disable sierra trade simulation mode? all orders will be sent to the connected trading service existing simulated orders will no longer be processed or filled
[2020-03-19 22:22:17] |
In order to disable Trade Simulation Mode you need to have your Data/Trade Service Settings set to a Trading service. Right now, your Data/Trade Service is set to SC Data - All Services. What trading service do you want to use? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-19 22:22:38
