Date/Time: Wed, 05 Feb 2025 14:00:24 +0000
Crosshair Control Button
View Count: 831
[2020-03-19 17:59:04] |
User910795 - Posts: 35 |
I downloaded the current version today to make sure I was up to date. After doing so the Crosshair button on the control bar was gone. I have looked high and low but cannot seem to find a way to get another crosshair control button on the control bar. I can get a crosshair when I right click but I find it more expedient to have a button on the control bar.
[2020-03-20 03:48:44] |
The button is still there, it just has a label now (Chart Val) instead of an image. Refer to first note for release 2065 here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
