Date/Time: Sat, 08 Feb 2025 08:33:57 +0000
Last trade price box setting not remebered
View Count: 1069
[2020-03-19 17:38:08] |
BenjFlame - Posts: 335 |
Hello, on individual chart set NOT to use global setting, I set last trade price box with a white background. As you can see on image it's properly set. However each time I close Sierra with saving, this setting is not remembered and I must reset it for my 10 charts. Can you confirm this is a wrong behavior? |
[2020-03-19 23:30:36] |
Makes no sense to us. We cannot reproduce this. Does anyone else observe this problem? We would not expect that to be the case. Maybe the Chartbook you are using is getting modified for unknown reasons. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-06 22:59:43] |
joshtrader - Posts: 500 |
Note that I think this is the same issue: Trade and Chart DOM Color Settings Changes |
