Date/Time: Wed, 05 Feb 2025 14:01:40 +0000
maintaining composite volume by price when rollover futures
View Count: 523
[2020-03-19 07:28:41] |
User879838 - Posts: 32 |
hello is there a way to maintain an accurate composite volume by price when rollover futures ? thanks |
[2020-03-19 07:39:07] |
here is example of monthly profile when rollover all VBP data before the rollover is gone is there a way to adjust that ? |
Screen Shot 19-03-2020 at 09.38.png / V - Attached On 2020-03-19 07:38:54 UTC - Size: 87.33 KB - 191 views |
[2020-03-19 09:31:12] |
Yes you need to set the chart to a Continuous Futures Contract chart: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-19 09:54:53] |
o.k. thanks !
