Date/Time: Wed, 05 Feb 2025 13:52:19 +0000
Using SC with the other client
View Count: 574
[2020-03-19 03:17:40] |
User587664 - Posts: 3 |
Hello I am currently using SC with Denali datafeed and I like both of it more than former data feed. IS it possible to use SC to put orders into the broker that doesn't support SC but API? For example, if I click the price of the DOM chart(or right click and click limit buy)on SC, will SC send the limit order information as well as price information to the API? Date Time Of Last Edit: 2020-03-19 03:24:03
[2020-03-19 03:27:48] |
This is not supported. But we see you are using the Sierra Chart Order Routing service and that works with many different clearing firms. So you could open an account at another clearing firm if you want.
[2020-03-19 03:41:45] |
For clarification, the broker supports FIX, OCX, COM. None of these are connectable? Or can I use ACSIL to do what I want to do? I found this Using API /w ACSIL and it seems like same as what I want to do Thank you for your help!! SC! Best, Date Time Of Last Edit: 2020-03-19 03:44:52
[2020-03-19 03:49:46] |
No, unless there is very specific support for that broker there is not direct compatibility. You certainly can use ACSIL and develop your own solution. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-19 03:49:54
