Date/Time: Wed, 05 Feb 2025 14:13:29 +0000
Error Message on Alert Log
View Count: 605
[2020-03-18 22:59:48] |
User358827 - Posts: 21 |
Hi, I have recently (last 2 days) been receiving the following error message in my alert log. The alert log pops up over my charts when trading. The error message is as follows: "Alert message error: The support@sierrachart.com was opted out from receiving Alert notification messages, contact Sierra Chart support." I would like to know what is causing this error and how I can fix it to eliminate the alert message log from popping up. Thanks. |
[2020-03-19 17:08:55] |
You have an alert that is set to have an email sent and it is trying to use the email associated with your account, but that is not set properly. Either uncheck the option to have an email sent or set your correct email for your account. Refer to the information here for unsetting the option to receive emails for an alert: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#EmailNotifications Follow this link (and login if necessary) to change your email address: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-21 10:44:22] |
Also disable this option: General Settings Window: Show Alerts Log On Study Alert (Global Settings >> General Settings >> Alerts >> Additional Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
