Date/Time: Wed, 05 Feb 2025 13:54:21 +0000
Background image for personalization Chart
View Count: 643
[2020-03-18 22:58:50]
hermeticio - Posts: 10
Kind regards support ...
There is a way to put a background image on the graph ...
since you cannot find this option in the current version ...
or if you plan to use it in future updates.
Cheers
[2020-03-19 03:24:32]
This is not supported.
[2020-03-19 19:37:10]
a suggestion that would help people who want to see historical data in the future ...
the option chart setting> advanced Settings ...
there is an option available to combine the historical data ....
this option appears in NONE ...
I would recommend that the option of
Continuous Futures Contract - Data Rule Rollover, Back Adjusted
It would help people how many days they want the data to load
imageAnotaciĆ³n 2020-03-19 143425.png / V - Attached On 2020-03-19 19:35:27 UTC - Size: 53.12 KB - 248 views
