Date/Time: Mon, 25 Nov 2024 03:32:05 +0000
Chart Y Axis issue
View Count: 1172
[2014-01-10 05:12:46]
Discount - Posts: 73
How do I widen the vertical Y Axis on a chart. I have a 6JH4 chart open, and the vertical Y axis is so narrow, I can not see the price. Also, how do you add more prices in this vertical Y axis, as on this yen chart, there are only 3 prices showing. Thanks
[2014-01-10 05:33:51]
Refer to this help topic:
http://www.sierrachart.com/index.php?l=doc/helpdetails32.html
[2014-01-10 06:25:19]
http://www.sierrachart.com/image.php?l=138933489771.png
Can you take a look at the Vertical Y axis. This is what I am trying to widen, and add more prices in, and I can not figure out how to do this. Thanks
[2014-01-10 06:51:14]
We have updated the symbol settings for the Japanese Yen futures for TransAct. Update the symbol settings on your side following the instructions here:
https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps
Be sure to follow each and every one of the steps.
Date Time Of Last Edit: 2014-01-10 06:51:34
