Date/Time: Mon, 25 Nov 2024 04:37:02 +0000
sc.ValueFormat = 1
View Count: 1429
[2014-01-09 23:24:04] |
onnb - Posts: 662 |
I understand that sc.ValueFormat controls the study value format - what appears in the study settings on the left hand side - right? I am setting this value to 1 in the defaults section but it stays inherited in the UI - not sure why. Onn |
[2014-01-10 10:16:09] |
It may be overridden if the study is set to display in Chart Region 1.
[2014-01-10 17:15:28] |
onnb - Posts: 662 |
Just to make sure I understand - it is expected not to "work" if the study is in chart region 0? |
[2014-01-10 22:27:22] |
Yes, it would be overridden. Is the study in Chart Region 0? However, this is very easily solved just by setting the Value Format outside of the sc.SetDefaults code block. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-10 22:27:53
