Date/Time: Wed, 05 Feb 2025 12:51:29 +0000
second computer will only show SC on SIM
View Count: 451
[2020-03-17 16:37:43] |
User815474 - Posts: 7 |
Hi I installed SC on a second computer an this will only allow the SIM option, can you help?
[2020-03-17 17:01:52] |
You need to set Global Settings >> Data/Trade Service Settings >> Service to the external trading service you want to use.
