Date/Time: Wed, 05 Feb 2025 12:58:20 +0000
Control bar drawings became text
View Count: 502
[2020-03-17 16:06:21] |
User964132 - Posts: 93 |
after last SC upgrade (to version 2065), almost all my control bar drawings became text only, How can I change this back to drawings as should be the default? |
[2020-03-17 18:13:28] |
Refer to the first note here for version 2065: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
