Date/Time: Wed, 05 Feb 2025 12:41:40 +0000
Earn2Trade
View Count: 818
[2020-03-17 15:20:01] |
User544164 - Posts: 6 |
Hello, I'd like to ask for your help. I am at Earn2Trade comppany for founded account and they give me 2 accounts. One is simulated and the other for operations of a fonded account. The problem is that all operations are done to me in a simulated account. And I don't know how to connect to the right account. Could you advise me how to make it?Yesterday I solved it for 5 hours with Earn2Trade support, but they didn't know where the problem might be and that I had to contact Sierra Chart support. Please, could you help me? Thank you very much, Pavel
[2020-03-17 18:05:49] |
The first thing to do is to disable Trade >> Trade Simulation Mode On on the main menu. And then you need to change the Rithmic connection settings in Global Settings >> Data/Trade Service Settings to the Rithmic account you want to use. You need to contact Earn 2 Trade for those settings. We do not know what they are. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
