Date/Time: Wed, 16 Sep 2026 04:55:30 +0000
DOM order settings
View Count: 891
[2020-03-17 14:10:27]
User232042 - Posts: 35
Hello, In regard to the picture below, I will try too short the market at $2384.00 in its current position. Instead of putting a sell limit order at $2384.00, it will sell me at market ($2385.25). Please help me with this, thanks in advance.
imageDOMHELP.PNG / V - Attached On 2020-03-17 14:10:15 UTC - Size: 35.79 KB - 395 views
[2020-03-17 19:29:00]
You cannot put a Sell Limit at a lower price than the market, as the current Market Price would give you a better fill. You would need to make it a Stop Limit in order to do this.
Refer to the Order Types here:
Order Types: Order Types
[2020-03-24 15:03:53]
I tried this on my DOM and couldn't get it to work correctly - I will post an image below. I have the order type set as "Stop-Limit" and I clicked on the price 2373.00 on the BID column attempting to get filled as a buy when the market hit this price. Instead, I got filled at BID MRKT price. Please let me know if I am doing anything wrong, thanks.
image3.PNG / V - Attached On 2020-03-24 15:01:11 UTC - Size: 49.61 KB - 315 views
[2020-03-25 09:15:40]
If you clicked in the Chart DOM then this would explain what is happening. When you click in the DOM, the actions are defined by the settings as defined here:
Global Trade Settings Windows: Chart DOM Settings
It does not use what is defined in the Trade Window for the Order Type at that time.
