Date/Time: Thu, 06 Feb 2025 05:13:40 +0000
bigger font?
View Count: 807
[2020-03-16 20:34:40] |
johndoe101 - Posts: 6 |
2 quick questions, 1) I'm using the numbers bars study but I'm having trouble reading the numbers because the font is too small. I tried zooming in real close on the Y axis but it's all crunched together still. Is there a way to enlarge these numbers to be readable? 2) When I do the ES futures it doesn't update in real time. But the SPX500 does work real time. I'm using the most recent valid ES contract. Not sure? |
[2020-03-17 04:55:38] |
First you must update to the very latest version. You are running an unsupported version at this time. Instructions: Software Download: Fast Update We will not provide support for the version you are on. And it is going to get locked out before June. To change the font size, refer to the documentation here: Numbers Bars: Font Size and Style for Numbers Bars For delayed streaming data for ES futures use this service which requires the latest version: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-07 07:20:14
[2020-04-06 23:20:03] |
Hi, I got it working but it's delayed. Is all CME future data via Sierra delayed? Even with a paid Sierra subscription? |
[2020-04-07 07:21:29] |
If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-15 17:45:03] |
Thank-you so much! That link was very useful and I got it to work! I now have a different question I'll post in this same thread if you don't mind. I have a chart with a lot of studies and I want to copy this chart for different products. I know how to change what symbol the chart is doing, but how do I copy it? |
[2020-04-15 18:29:12] |
John - SC Support - Posts: 37769 |
Refer to the following: Chart Menu: Duplicate Chart (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-16 21:17:34] |
That also worked! Your help is most appreciated! Great job
[2020-04-16 23:48:20] |
To View the DOM in Sierra for CME futures, do I have to pay for level 2 from Interactive Brokers first?
[2020-04-17 09:44:48] |
Yes or you can use the Sierra Chart Denali Data Feed for this: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
