Date/Time: Wed, 05 Feb 2025 12:52:30 +0000
No data feed update
View Count: 475
[2020-03-16 18:34:39] |
Brian Connolly - Posts: 9 |
My data stopped updating today. My account says I should have active data. I have a green bar in the upper right corner.
[2020-03-16 18:37:32] |
You need to connect Sierra Chart to your trading account to meet CME rules: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-16 18:38:31] |
Refer to this post: Denali and TD ameritrade | Post: 209017 And also refer to our answer above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
