Date/Time: Wed, 05 Feb 2025 12:55:57 +0000
Extended Point & Figure features
View Count: 547
[2020-03-15 12:41:32]
BeardPower - Posts: 51
Is it possible to show a similar chart view like the one in Updata (charting paper, squared grid, fixed 45° drawing lines etc.) with the current functionality?
If not, could this be provided?
Date Time Of Last Edit: 2020-03-15 12:42:08
[2020-03-17 03:22:23]
The Line tool, does support specifying an angle before using the tool:
Chart Drawing Tools: Drawing a Line with a Specific Angle
So you can set it to 45°.
Otherwise, the other described items are not supported in the way that you are looking for.
