Date/Time: Mon, 25 Nov 2024 03:24:05 +0000
Chart Header Bug
View Count: 1154
[2014-01-09 18:18:42] |
GCAdmin - Posts: 35 |
Everytime I go into Global Settings --> Customize Chart Header, even if I just cancel out of that window, it resets my chart header settings. Is this a bug in the program of some kind? |
[2014-01-09 19:20:45] |
We cannot duplicate this problem. If you press Cancel, there will be no changes. We have never heard about a problem with this previously.
