Date/Time: Wed, 05 Feb 2025 10:42:49 +0000
Icons have turned to text on update
View Count: 623
[2020-03-14 18:58:22] |
User459170 - Posts: 262 |
I updated to the current version and the icons like line, ray, etc. have turned into text. Will you be fixing this soon? Thanks.
[2020-03-14 20:42:38] |
This is controllable by the user. We have complete details in the first item for version 2065: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
