Date/Time: Wed, 05 Feb 2025 10:44:47 +0000
Changing the control bar menu
View Count: 1359
[2020-03-14 14:29:12]
User94606 - Posts: 327
How do I change the tool buttons on the control bar from text to icons/images. As an example, the the line button has the word "Line" and not the line symbol (______) - see attachment
imageTC.jpg / V - Attached On 2020-03-14 14:29:03 UTC - Size: 64.57 KB - 288 views
[2020-03-14 16:49:54]
User21113 - Posts: 62
Right click the toolbar
Select 'Customize Control Bar 1'
Select the Command from 'Selected Control Bar Commands'
Select 'Properties' Button
Set the text with 'Button Caption'
Set the Image with 'Set Image'
[2020-03-14 17:48:38]
Thank you. Do you know if there is a way to do change it to image once globally?
[2020-03-14 21:46:34]
See this posting, Control Bar button which should answer your question.
[2020-03-16 07:30:31]
Refer to the notes here for Control Bar buttons for version 2065 in regards to this:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065
Date Time Of Last Edit: 2020-03-16 07:30:38
