Date/Time: Wed, 05 Feb 2025 10:54:37 +0000
After last update 2065 aplication lost some of the icons!
View Count: 711
[2020-03-13 21:08:53] |
b3cker - Posts: 34 |
For example instead of icon I see "Gann Fan" or "Vert Line"
[2020-03-13 21:20:14] |
ForgivingComputers.com - Posts: 994 |
Same here. Went back to 2060.
[2020-03-13 22:06:28] |
ScoTTyBEEE - Posts: 5 |
Same. 2065 and 2066 have the same problem. Switching back to 2060 fixed it.
[2020-03-14 00:47:34] |
Refer to the first sub note for version 2065 for what to do to display the previous images: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
