Date/Time: Wed, 05 Feb 2025 10:44:26 +0000
Trial account for stock data
View Count: 649
[2020-03-13 17:15:30] |
User769783 - Posts: 188 |
Can someone assist me in creating a demo account for stock data. I have a live account for futures data only. Thanks
[2020-03-14 00:49:28] |
Did you want real-time or only historical stock data?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-14 00:49:45
[2020-03-14 03:14:04] |
Historical is okay...
[2020-03-16 10:25:07] |
You are going to need a direct Sierra Chart account: Direct Sierra Chart Account And then you can use the Sierra Chart historical data service with that account: Sierra Chart Historical Data Service You want to install a separate copy/instance of Sierra Chart which the Set up Instructions in the documentation explains. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-16 10:29:28
