Date/Time: Wed, 05 Feb 2025 10:58:13 +0000
Future Symbols due to new SC installation
View Count: 538
[2020-03-13 15:16:06] |
fraalbe - Posts: 12 |
Hi, my software had an update, so I was forced to reinstall SC. All was fine. Now I am missing the FUTURE DATA via CQG for my markets CL, FDAX, FESX, FGBL, ES, NQ, YM, XBTUSD, 6E, FDXM, ESmini. I get the data feed by CQG. How can I find the right symbols in the FS window?
[2020-03-13 16:38:06] |
First we see you are using an older version of Sierra Chart. You need to update. Instructions: Software Download: Fast Update Follow the CQG setup instructions: CQG Trading Platform Service And then make sure the symbols are set correctly in the charts. You can do that with the Edit >> Translate Symbols to Current Service command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-13 16:38:19
