Date/Time: Wed, 12 Feb 2025 22:18:42 +0000
Study Help
View Count: 1081
[2020-03-13 12:52:48]
Critcendo - Posts: 11
Hey SC Team & Community,
Are there any well known gap fill studies out there? I've done some extensive searching and have come up empty with what I'm looking for.
A study that can plot the difference between the previous close of day and the current day's open. In addition to this data, I'd like there to be an extending rectangle (not necessarily the tool) that extends until future intersection. All on a day session only chart. Example attached for yesterday only. Drawn manually.
I'm not asking for this to be programmed, I can do that myself. I'm only asking two questions:
1. Does a study like this exist in SC?
2. If not, how would you recommend creating something like this? I can do the programming on my own.
Thank you guys so much!
imageSCEx.png / V - Attached On 2020-03-13 12:52:36 UTC - Size: 110.36 KB - 586 views
[2020-03-16 12:38:44]
ForgivingComputers.com - Posts: 1001
You can try the study Extend Bar Gap Until Further Intersection to get all the open gaps, not just the one from the day before.
[2020-03-16 17:46:51]
1. The closest that is available is this study:
Extend Bar Gap Until Future Intersection
2. The only way to accomplish this kind of Draw Style is to use Study Subgraphs but there are only so many of them. But if you are just extending the most recent gap that should be fine. Refer to:
Chart Studies: Fill Rectangle Top (ACSIL: DRAWSTYLE_FILL_RECTANGLE_TOP) and Fill Rectangle Bottom (ACSIL: DRAWSTYLE_FILL_RECTANGLE_BOTTOM)
As far as other implementation details, you need to work those out.
Date Time Of Last Edit: 2020-03-16 17:47:12
