Date/Time: Tue, 04 Nov 2025 18:18:15 +0000
[User Discussion] - Can I create chart based on best bid/ask instead of Last (not FX
View Count: 2728
| [2013-04-14 18:58:29] |
| maxima120 - Posts: 157 |
In FX world is usual to have data split to bid and ask and last. so it is easy because the data feed supports it. however if I want to chart best bid / ask for a future? shall I create custom chart? can it be done non-programmatic? |
| [2013-04-15 17:12:25] |
Refer to Data Recording Modes in the documentation.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-16 06:42:00
| [2013-04-15 23:48:25] |
I would like to know - can it be done from the UI without writing a custom chart. yes/no/yes(but in certain circumstances). If you are not bothered to give the answer just stay away. Perhaps a user will answer. |
| [2013-04-16 13:35:15] |
| Sawtooth - Posts: 4285 |
http://www.sierrachart.com/index.php?l=doc/doc_RecordingModes.php
| [2013-04-16 13:58:50] |
Thanks..
